I have loads of good customer maps so I am sure I would have one to suit your blade. This is the 4 injector plug version and so it will fit and wor on all blades from 2008 - 2016. The first Blade PCV plgged into the no 1 and 4 injectors and then the injection sub loom. They revised that loom for 2012 and the later Power Commander 5s plug into each of the primary injectors. I 110% guarantee that it will plug into any 2008 - 2016 Blade. Comes with. Full instructions. http://www.powercommander.com/downloads/16-034/install/pcv/eng16-034.07.pdf USB cable. O2 sensor eliminator. Software on CD. Stickers. The PCV itself. Dynojet UK supplied and in its orginal box. £165 - No offers its £165. UK post is £5. Paypal is fine.
I have a 2013 Fireblade with a Racefit exhaust at the moment would you happen to have the map for this ? Also how difficult is it to fit ?
Its a very easy fit mate. I actually put a link to the fitting instructions so you can see. Pop up the tank. Unplug the lower injectors. Plug each end into the corresponding plugs on the PCV and plug in the TPS. Its essentially a plug and play and yes I have a racefit map.
