cbr1000rr 08+ part out!!!!
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Jun 2, 2012.
  1. vic_ster51
    vic_ster51 Active Member
    All parts below are from a 2009 repsol fireblade, all prices inc postage, other parts will be added in time
    clear led rear light, is a factory honda light off a blade not a copy etc
    perfect conditon - £40
    R&G Bar Ends fits lots of honda's
    Honda BE0007BK Bar End Protectors
    same as above, unmarked £20 posted, will come with oem bolts aswell unlike the kit you buy
    Complete lockset and ecu- ignition barrel, fuel cap, rear seat lock, Ecu (as ecu works with key) hiss sender etc 2 keys, everything to bolt on and go basically
    £450 posted or £530 posted with the top yoke
    Honda front support clock bracket
    Standard original honda black front fairing, frame support clock bracket
    £80
    Rear subframe in silver, complete with bolts,plastic undertray and the 2 support brackets etc
    Straight and v.good condition
    £250 posted
    Standard Chain Guard - £15
    Brake single banjo bolt with brake light switch and oem connector ready to mount - £12
    Rear passenger pegs and bolts - £25
    Rear wiring loom for indictors etc no cuts as new - £12
    Repsol underseat fairing, honda part few light stone chips £15
    not a scuff on pic, reflection etc
    R&G Tail Tidy, no number plate hanger, has mounting bolts - £25
    09 rear indictors good working order - £35 for pair or £20 each
    Race Fairing rear seat unit and undertray, came from ron haslam race school, fits stock subframe and uses stock seat - £45
    Riders seat, great condition with bolts - £45
  2. lambeth longshanks
    I'm after bar ends and tail tidy if still available.
  3. tgosai
    tgosai Member
    hi, are you selling the wheels ?
