cbr1000rr 2004-16 hm plus quickshifter for sale, perfect working order fully complete, may need to buy another rod depending on your setup, these are like £10 anyways £200 posted Strain Gauge activated. Nothing else outside of MotoGP uses this technology. No moving parts mean the HM Quickshifters make them virtually indestructible. HM Plus Quickshifters are the kindest and gentlest way to treat your gearbox. HM uses the ignition side of the motorcycle to unload the gearbox, which is far kinder than most other designs that cut from the fuel side. HM Plus Quickshifters are STAND ALONE systems, integrated into the ignition side of the motorcycle as a quick shifter should be. Every function is controlled from the LCD screen. (Compression/Extension, Sensitivity, and Kill Time) Every HM Quickshifter works in EITHER the up downshift pattern. (standard or GP shift) HM Motorcycle Quick Shifter is fully adjustable for ignition kill time. Transportable – Can use it on multiple machines. (with the correct wiring loom) Wiring looms are plug-in and go.
