CBR1000RR 2010 bi-xenon projectors
Discussion in 'Mods, Upgrades, Accessories and Products' started by tgosai, Dec 3, 2012.
  1. tgosai
    tgosai Member
    Hi,
    managed to fit bi-xenon lens to my light housing this weekend, have a look at the pics and tell me what you think ?
    tgosai's Album: 2010 Blade - bi xenon project
    will post more pics once i've fitted the front on to the bike
    • Like Like x 7
  2. explorer
    explorer Member
    They look great, will you get two headlights lit on dipped beam ?
  3. tgosai
    tgosai Member
    Thanks, yeah it'll have twin lights with high/low on both sides.
    Personal preference, but I think it looks much better with two lights rather than the single sided OEM's
  4. Muffking
    Absolutely love it. Which kit did you use? Was it a 2 lamp H7 HID kit like you use in a car?
  5. explorer
    explorer Member
    Were they easy to fit ?
  6. tgosai
    tgosai Member
    Yeah a kit bought from China, did a lot of research in to and all ones available from a UK company are in fact similar or exact same to the ones made in China, just costs a bit more.
    I think it doesn't matter whether its for a car or bike, as long as it a H7 fit and has slim ballasts
  7. tgosai
    tgosai Member
    The actual work wasn't that difficult but the prep work was, I needed to figure out the wiring to power both lens form low and high beams.
    There's a ton of videos on youtube of people showing how to open lights and install the lens kit. The wiring part I had to take my time and think it through a bit.
    So if I can do it, any one can, I'd defiantly encourage you to give a go, I got a lot of satisfaction doing this, I'll get even more once it's fitted on :)
  8. kpone
    It looks fantastic Tgosai. Am I the only one that is envisioning a raptor beak on the nose cone?
  9. ChrisOzzz
    ChrisOzzz Active Member
    They look awsome..
    Do you think there will be any heat issues? Wont they generate more heat than the originals?
    Ozz
  10. phantom
    phantom Active Member
    very nice....do you think you could have a go at making these next
  11. tgosai
    tgosai Member
    It does get hot, but no more heat that halogen bulbs would generate, these are the 35w ballasts, the halogens are 55w. The ballasts get warm so had to fit them where there good circulation.
  12. tgosai
    tgosai Member
    The kit that I bought does most of that, apart from the LED trim round the sides. But from what I read, it's fairly simple, it's an LED strip light that goes round the trim
  13. kpone
  14. thezipsteruk
    thezipsteruk Elite Member
    there very nice mate very nice indeed, I would love to mod mine with these!
    No way my idiocy with electrics would cope, would love to find an installer tbh
    great upgrade and really visual too
  15. Muffking
    So did you stick your headlight in the oven to split it then?
    And how does the projector lamp fix into place on the inside of the headlamp?
  16. tgosai
    tgosai Member
    Yeah, had to put the whole unit in for a few mins, have to be very careful though, mine were almost at the point of melting. The other options to use a hair dryer, but that seems a bit too long winded.
  17. Muffking
  18. phantom
    do you fancy writing a guide up?
    could be a good sticky subject
  19. tgosai
    tgosai Member
    yeah, thats pretty much the kit i used, with 6000k but didnt connect the halo or daytime running ligh, i wanted to go for a classic look without over doing it on the other bit, and my lights are set up as standard to come on full once i turn the ignition on. I guess you could have the running lighton but would mean adding a rocker switch for turning main light on/off.
  20. tgosai
    tgosai Member
    yeah, i thought about that after completing it, but not sure how good my explenation would be with out decent pics to demonstrate what im doing.
    i'll try and do one and hope it makes enough sense to help people.
