OHLINS PRXLS - RACE REAR SHOCK. TYPE 46 - NOT THE TTX. 1. REMOTE PRELOAD. 2. RIDE HEIGHT ADJUSTMENT. 3. HIGH AND LOW SPEED COMPRESSION. 4. REBOUND ADJUSTER. 5. REMOTE RESERVOIR. 6. 46mm PISTON. THIS SHOCK IS FULLY SERVICED AND IS PRESENTLY ON A BIKE I WAS BUILDING BUT DECIDED TO DO SOMETHING COMPLETELY DIFFERENT. ITS OFF A 2006 BIKE BUT WILL FIT THE 2004 - 2005 RR4 RR5 PERFECTLY. IT WAS SPRING FOR ME WHEN I WAS 14 STONE FULLY KITTED UP SO WUILL SUIT 12 - 15 STONE PERFECTLY. ANY LIGHTER AND YOU WILL NEED A LIGHTER SPRING. 15 - 16 STONE YOU WILL NEED TO BE WELL ON WITH THE PRELOAD. OVER 16 STONE - GO ON A DIET YOU FAT FECKER ;-) THE SHOCK IS STILL ON THE BIKE SO THE PICTURES ARE NOT BRILLIANT BUT IF YOU ARE GENUINELY INTERESTED I WILL TAKE IT OUT. IF ONCE YOU GET IT YOU ARE UNHAPPY I DO RETURNS NO PROBLEM. THE SHOCK IS IN GREAT CONDITION AND WAS FULLY SERVICED BEFORE I STARTED THE REBUILD. I TOOK PICTURES OF THE AREAS THAT WOULD NORMALLY BE KNACKERED. LOWER RIDE HEIGHT NUTS AS WELL AS THE REBOUND ADJUSTMENT. THE HIGH AND LOW COMP AND REBOUND AT THE TOP IS UNMARKED. SPRING IS IN EXCELLENT CONDITION. SLIGHT DISCOLOURATION ON THE CLAMP THAT MOUNTS THE PRELOAD ADJUSTER BUT THAT IS ALL AND ISNT NOTICABLE ONCE FITTED. THE PRXLS IS THE PREVIOUS TYPE OF RACE REAR SHOCK. SOME SAY EASIER SET UP THAN THE NEWER TTX. I AGREE BUT THATS MERELY AN OPINION. MARK ARNOTT WHO WAS TAS SUZUKI OHLINS MAN DOES MY SERVICING AND HE WILL COVER MY 6 MONTH WARRANTY. CLEARLY NO RACING NOW TILL MARCH SO IF YOU HAVE A RACE LICENCE I WILL WARRANTY FROM MARCH. LOOKING £500 OVNO... LIKE VERY NEAR.
