CBR1000rr radiator
Discussion in 'General 1000RR Discussion' started by boris, May 6, 2012.
  1. boris
    boris New Member
    Hello all!
    New to the forum, new to forums in general!
    Got a problem if anyone can help? Got a hole in my rad a few weeks ago put some radweld in it and it stopped is this a repair that i can trust or would you consider this temporary?
    Also would a rr6 - rr7 rad fit a rr4?
    Thanks
  2. Dave V
    Dave V Elite Member
    Had the same issue, get it repaired or replaced. Repairs are circa £40 if you strip and take the rad in
  3. viper_biker
    viper_biker Active Member
    An RR6/7 will fit an RR4/5, but not the other way around. The RR4/5 radiator doesn't fit with RR6/7 bodywork as the bike is a bit thinner.
  4. scooby
    scooby Elite Member
    #4 scooby, May 13, 2012
  5. boris
    boris New Member
    Thanks guys great help!
  6. dave d
    dave d Elite Member
  7. barry107
    barry107 Active Member
    Used this on my track bike rad, brilliant stuff; Halfords | Evo-stik Hard & Fast Metal Epoxy Putty
    Clean and dry area,
    Cut off section of putty,
    Kneed both parts together
    Place onto damaged area
    Shape and allow to cure
    You can smooth if before fully curing, you dampen the putty with water and smooth finish with your finger.
    Can also be filed, sandpapred or drilled when fully cured.
  8. morpheus20170
    morpheus20170 Active Member
    Sorry to start this thread again but I'm wondering if I will damage my bike by using Radweld/K-Seal as I've heard these are mainly for cars and I don't want to affect my engine/water pump, etc.
    Also I've found a 2nd hand rad in the US and through a breakers in this country but not sure whether to go with AaronRads for a cheaper repair or recore?
    Your views would be appreciated.
