Hey folks. Anyone running a TTX shock and SSK25 ktech front? What suspension settings are you using for your bike and whats your rough weight? About to get mine setup again but itd be interesting if anyone has any good data. Also if anyone has any geometry alterations or preferred wheelbase length? Ta
Wheel base from swing arm pivot to middle of axel. 590-605. As for settings I have 30 mm fit and ttx but wouldn't it be better to trust the setup put in it and work from there. As springs rates etc will mostl likely be different. There is a measurement for shock length il try find it if u like. Who's doin ur setup they should do that?
Jase is running a TTX rear and a NIX30 cartridge kit at the front. I'm sure he'll be along at some point tonight to let U know his settings or U could PM him as he will be busy with preparing for this weekends racing.
he does indeed have this set up but £5 says he hasnt a clue of the settings - my bet just like me it would be as per suspension guy's who set it up! lol
i reckon ur right stick to what they put in. thrum fiddle slightly if u feel u need it. who are u having to do the setup?
let them put the base set up in,then whenb you go on track,go see the suspension guys and talk to them after you've doen a session or 2 to get a feel,they will then talk to you as to what it is or isn't doing and change accordingly.
Both Jase and myself had full Ohlins supplied and fitted to our Track Bikes at KAIS of Manchester who are big on the UK Racing scene. Mine has been left as they set it, which was for my weight including specific springs and for Fast (but not extreme) Track use. I did however have the foresight to get them to email my settings over to me which maybe Jase didn't! Kais – Ohlins | The UK's number one performance centre
