cbr1000rr
Discussion in 'New Members' started by Blackrush, Oct 9, 2023.
  1. Blackrush
    Blackrush New Member
    Hi
    Have a 2011 fire blade when you go along in first or second gear try's to die at about 15MPH if i loop out clutch switch rides ok can any one help.
    #1 Blackrush, Oct 9, 2023
  2. Broadie
    Broadie Active Member
    Hi welcome.
    I'd suspect the sidestand switch would be worth looking into.
  3. Cookster
    Cookster Active Member
    Try a new clutch switch?
  4. Boothman
    Boothman Elite Member
    Hi and welcome to the forum.
  5. Blackrush
    Tested both switches work ok
  6. Blackrush
  7. Blackrush
  8. Blackrush
  9. Boothman
    If the Clutch switch is okay and when you ‘loop out the clutch switch’ it performs as it should it points to the wiring between your loop out and the switch itself. Check the wiring/connectors for damage/corrosion/lack of contact.
  10. Wes
    Wes Active Member
    2005 clutch switch wiring.
    Clutch switch pair has one cable directly linked to side stand switch and other goes back to starter relay (green/red) via diode in fuse box (if you have one) and ECU
    Side stand switch grounds other of your pair when the stand is up.
    Might help.
  11. BlackDevil
    BlackDevil God Like
    Hi and welcome !
  12. bradt
    bradt Elite Member
    Welcome
