Hi I’ve just up graded to a 2023 cbr1000rr sp and what a bike it is the question is the standard exhaust is way to quiet until 6000rmp if I was to remove the exhaust valve motor an put a eliminator on it what problems could happen my old 2019 blade had a slip on so valve was already removed tick over was a bit rough unless reved but other than that no problem I can not say if lacked touque low down as nothing to compair with. I’ve seen vids on you tube with same exhaust with valve removed it sounds ace but they never say anything about performance or running. Thoughts ?
