CBR929 Fireblade LCD Failure / Malfunction
Discussion in 'Maintenance' started by Merlin, Apr 15, 2012.
  1. Merlin
    Merlin Active Member
    Hi all,
    The LCD display on my 2000 RRY Blade has started to malfunction.
    It started with the speedo intermittently not reading my speed and staying at zero, now im lucky if it will work at all.
    Then a few weeks later my total mileage went from reading 21295 to zero then to 99999.
    My ODO is also not reading correctly, after a 42 mile journey to work it was only reading that i'd covered 31 miles.
    My friend has had the clocks apart to see if there has been any water ingress or scorch marks from bad wiring but its all good and from what we can tell the wiring is fine too from the clocks back.
    Can anyone please shed some light on this problem or maybe offer some advice as were now both stumped.
    Thanks
  2. Hudson
    Hudson Active Member
    Hi Pal,
    I am sorry i can not assist, i have a 954 and find a forum with members who have mostly 929/954's may be best. Have you tried www.cbrforum.com
    It has a specific section for the 929 (and the 954), they may be more aware of this issue. I assume most members on here own the later 1000cc bikes..... well maybe not all, but most.
