Is there any difference in specs between a 2007 swing arm and a 2010 swing arm will chain adjusters from a 2007 fit a 2010
Your probably right it's just that's there's some lightechs on eBay for a 07 and I was wondering if they would fit my 2010 if you go on the Giles website the same ones are listed for 04 to 2015 making me think they were all the same size
I see that on the Gilles site it lists the same part number,but on lightech it lists them separately. It may be that the area where the adjuster block slides is a different length on the 06-07 blades,the Gilles would still work as it slides but the lightech has to be a perfect fit as it bolts in tight.
