chain alignment
Discussion in 'Maintenance' started by rebel, Feb 23, 2016.
  1. rebel
    rebel Active Member
    I'm trying to accurately check the wheel alignment apart from a straight edge or the string method which seem totally useless to me can someone tell me if I measure from point a to point b with a Vernier gauge will this accurately align my wheels 2016-02-23 12.31.25.jpg
  2. Slick
    Slick Elite Member
    I've previously used your proposed method but the rounded edges etc make consistent measuring difficult. Also a small distance translates to a much bigger deviation alot the edge of the chain.
    laser is the way to go for uber accurate alignment. I use mine in conjunction with my lightech adjusters which FYI are 1mm out according to the laser, - I trust the laser!
    my previous renthal have very little wear over 10k, shame the chain fell apart!
  3. sp1n99
    sp1n99 Active Member
    Profi D-Cat laser tool is what you need.
    Otherwise Google motorcycle rear wheel alignment to see a vid of the proper way to do the rope trick.
  4. Dave dunlop
    Dave dunlop Elite Member
    I find it easier from the back part of the swingarm, and just use a vernier, it's flatter and no odd angles to overcome. It's also pretty much bang on with the laser....
  5. Dave
    Dave Member
    Problem you may encounter with checking with a vernier is you are setting the rear wheel correct to the swingarm and not correct to the front wheel:(. Over many years of setting up motorcycles the straight edge method works very well and now lazer alignment. A tiny amount of movement at the chain adjusters becomes a huge amount at the front wheel:eek:.
  6. rebel
    rebel Active Member
    If the rear wheel was out of alignment by 1 or 2mm would you actually notice any difference when you were riding
  7. Slick
    Slick Elite Member
    Can't comment if it affects handling but over a distance your sprockets will start to suffer, a little wear on the rear sprocket will be exaggerated on the front.
    Got a dot type profi-cat laser myself, if you have the cash the L type is much better.
