Chain Break/Rivet Tool
Discussion in 'General 1000RR Discussion' started by hitch, Jun 7, 2018.
  1. hitch
    hitch Elite Member
    Any tips or recommendations?
    Been searching ebay and the choice is extensive :confused:
  2. raphael
    raphael Elite Member
    I use one called whale, have used it for 3 years now (3 chains)and no worries about it breaking, heavy duty bit of kit
  3. hitch
    hitch Elite Member
    I've seen those, it's the one where you have to use a 2lb hammer to rivet the master link pins? ...some have a threaded bolt or similar to manually tighten and rivet.
  4. raphael
    Yes that’s right mate, a good wallop is needed but I’m pretty sure you would only buy it once lol
  5. hitch
    hitch Elite Member
    Haha, OK cheers
  6. Kentblade
    Kentblade God Like
    Been using a DID KM500 for about 25 years, bulletproof and sets the side plates correctly, and if used properly does not damage the pin when you rivet it
