chain help.
Discussion in 'Maintenance' started by keithg1748, Jun 4, 2016.
  1. keithg1748
    keithg1748 Active Member
    morning all just a quick one , what are your thoughts on just replacing the chain on a 13 plate with 1800 miles the sprockets seem fine but standard chain looks crappy with rust , tried cleaning but cant shift it ,and which make of chain ? thanks for any info.
  2. Nickw
    Nickw Active Member
    My chains generally last me about 20 - 25k
    They need regular cleaning and maintenance, otherwise they'll rust up.
    I think my last one was a Gold DID X ring. I've not put one on this bike yet...
  3. PeterT
    PeterT Active Member
    Just replaced my Tsubaki after 12000 miles. Given that milage I would think it will be ok just changing the chain. Make sure you inspect the sprockets before you put a new chain on though.
  4. bonjo
    bonjo Active Member
    gosh 1800 miles only! not matter what you fit it will end up the same way.
    If it is surface rust, then give it a good clean (toothbrush and kerosene/ diesel) and a good lube. After a 3~4 riding/ lubing sessions the chain may be back to normal.
    If the lube inside the rollers have gone, then you may have to replace it (don't forget the sprocket). I would go for RK. but each has his/her preference
