Chain Lube Experiment
Discussion in 'General 1000RR Discussion' started by Slick, Nov 23, 2014.
  1. Slick
    Slick Elite Member
    Been conducting an experiment on the best lube for a commuting chain i.e. all weathers dirty roads, salt etc
    My definition of a good lube is (in no order)
    1 Corrosion protection
    2 zero fling
    3 Penetration into the rollers
    4 does not attract crud in wet or dry
    5 does not degrade the rings
    I tested the following lubes/waxes
    SDOC
    Motul road lube
    WD40 Wax
    Muc Off dry lube
    All tests were conducted on mild steel washers, cleaned with chain cleaner and dried and warmed on a radiator before application of the lube
    1 Corrosion test
    Each washer was submersed in a salt water solution for a minute a day and left to dry these are the results after 3 days
    SDOC - zero corrosion 10/10
    Muck off -Poor corrosion resistance 4/10
    WD40 - zero corrosion 10/10
    Motul - OK corrosion resistance 6/10
    2 Fling
    Tested on bike, chained clean and lube applied tested for a week and rear wheel examined for spatter
    No photos sorry!
    SDOC - zero fling 10/10
    Muck off - zero fling 10/10
    WD40 - evidence of fling 7/10
    Motul - zero fling 10/10
    3 Penetration
    Sprayed on a steel plate to a 10mm dot and 'creep' examined
    SDOC - good creep seem to spread very well at least 2-3mm -8/10
    Muck off - quite thick on application didn't spread - 6/10
    WD40 - very thick on application didn't spread - 6/10
    Motul - very thin, spread 3-4mm- 10/10
    4 Crud attraction
    wet test - crud solution made of water mud and sand and blue glitter and poured on test subjects
    all tests resisted crud attraction in the wet - all 10/10
    Dry test - a mixture of dry sand and blue glitter then and sprinkled on subject
    SDOC - medium evidence of attraction
    Muck off - little evidence of attraction
    WD40 - large evidence of attraction
    Motul - little evidence of attraction
    5 - Ring protection
    - not tested! took the manufacturer's claims as true!
    Conclusion
    This short test only covers the lubes tests tested.
    The Muc Off and Motul seem to be more summer/dry weather lubes and perform well resisting crud in the dry but suffer when it gets a little wet allowing a little corrosion.
    WD40 Wax and SDOC excel well in the wet providing great corrosion resistance.
    I don't think the WD40 and Muc off would penetrate the chain well thus providing lubrication in the rollers. The Motul and Sdoc seem to have great penetration qualities.
    All lubes tested showed little fling though the WD40 did fling a little
    But in the wet the SDOC wins hands down. Very good corrosion resistance in the wet and zero fling. As it is not completely clear you can see where it has been applied (unlike the clear Motul)
    That is all, the end!
    #1 Slick, Nov 23, 2014
    • Like Like x 16
  2. thezipsteruk
    thezipsteruk Elite Member
    Nice test cheers mate...wish you'd tested worth dry chain lube too.
    Can you do it again :rolleyes::D
  3. sps170373
    Looks like I'll be going back to sdoc when I've finished the muck off
  4. marco s
    marco s Active Member
    x2 :)
  5. Gilesy
    Gilesy Elite Member
    very nice Slick.. great review..
  6. PeterT
    PeterT Active Member
    I still use EP 80 gear oil.
  7. marco s
    Does the gear oil not fling like a bitch ??
  8. Slick
    Slick Elite Member
    I have tried Wurth a few years back and didn't find it fair well at all. Even in the summer found evidence of corrosion after a little rain. Wurth for me is a dry weather specific product, that 'flakes' off in use taking the crud with it, great in the dry but leaving little protection in the wet.
    This was a few years back mind so will give it a fair review if I can find a can locally.
  9. Slick
    Slick Elite Member
    Yes, I did this for a while too, applied with a brush every morning. Great corrosion resistance but I do a lot of miles and this is totally ball ache, made a mess of my wheel and garage!.
    Also while on the subject also had a Scott Oiler, also too messy. Does not work on the OEM sprocket - its got a channel than prevents proper lubrication. it only takes a day or two for it not to work to really feck up you chain!
  10. Mr OCD
    Mr OCD Well-Known Member
    I do like SDOC and Motul factory line ... Used most of them.
  11. Great Guy
    Great Guy Well-Known Member
    What about Castrol? And what is sdoc?
  12. Mr OCD
  13. Muffking
    Good test. Been ruining chains with Motul and was gonna move on to WD40 chain wax, but may reconsider now.
  14. Kentblade
    Kentblade God Like
    Top write up Slick, you might need to get out more matey, but you have sacrificed your personal life for the rest of us lazy farts.:)
  15. Remal
    good test and thanks for sharing. Looks like I may try SDOC sooner than later now
  16. keithg1748
    keithg1748 Active Member
    good test , I change to sdoc chain cleaner and chain lube a few months back and good stuff , the chain cleaner is good but you need to wipe off with a cloth , warning watch your thumb end as I took mine off . , doohh.
  17. Great Guy
    How did it take you thumb off? Is it like acid?
  18. keithg1748
    no drying chain cleaner while in first gear with a cloth , i know it was a daft thing to do , but it did a good job lol.
  19. jamesm09
    jamesm09 Senior Member
    :eek:
    Bet that hurt!
  20. Mr OCD
    Daft? You are lucky you didn't lose any fingers silly sod! I've seen a guy lose all four fingers from doing the same thing.
    Rotate the wheel by hand!
    Just cleaned mine with WD40 on a cloth and then run Motul factory line chain wax on it.
    Didn't realise they come with RK chains as standard ?
