How much tension do you guys put on your chain.. i know its all about feel, i like it pretty tight does everyone stick to the 30mm?
No expert Tyke but one would imagine "Tight = Problems " Stick to the 25\ 30mm all I do is get a steel ruler put it upto the under side of the swingarm and measure by pulling both up and down the chain.
Yeah I have done giv just got told by a lad who I ride out with that you can go tighter than manufacturer specs without any issues and rides better... but he's rather simple so I've stuck with Mr Honda's idea
eyeball a mid point between front and rear sprocket, rotate rear wheel till i find the stiffer spot then allow it 25-30mm play.
