Chain tight spot!!
Discussion in 'Maintenance' started by quattrochris, Jul 26, 2012.
  1. quattrochris
    quattrochris Active Member
    Hi guys, got an rr7 with 4500. Original chain but i fitted a renthal sprocket end of last summer and now have a tight spot? checked alignment and seems ok could it be my sprocket is not round? anybody come across this?
    Cheers Chris.
  2. rocket
    rocket Active Member
    with that low mileage on a 5 year old bike its probably just got a few stiff links from when parked up unused. just spin rear wheel by hand on paddock stand and see if you can spot any tight spots as it comes off the sprocket then try to free them up. renthal sprockets are good kit so can,t imagine you have an odd shaped one. lol
  3. scooby
    scooby Elite Member
    when you say tight spot,do you mean a link that isn't moving or just your chain is tighter in certain areas?
    for the latter i wouldn't worry about it as it happens,for the former,give your chain a good clean with some petrol or deisel and then lube with some chain wax etc and take for alittle run to work in into the links,or run (if you feel safe enough)it on a paddock stand for a bit.
  4. duck
    duck New Member
    I sent a message to B&C Express about tight/loose spot on chain and what was the best chain they sold, here is there reply which may help you identify were your problem is:
    • Like Like x 8
  5. PeterT
    PeterT Active Member
    Thanks.
  6. martinowen
    Good bit of info that duck, I will save that somewhere
  7. quattrochris
    Thanks duck thats my sunday afternoon sorted then! :)
  8. duck
    duck New Member
    I checked mine today and found it worked best marking the wheel and chain at the same time, on mine the tight/loose spots always occurred when the wheel was in the same position no matter where the chain position was, this points to a sprocket problem and not the chain.
    This was very interesting to me as I was going to just change the chain but now after the check it has proved chain and sprockets needed replacing.
