Never done it, but want to put my standard ones back on the bike, came with raised ones which I lowered to standard height but Ive snapped the pins in the rhs and now my bars are wobbling which I can assure you is quite unnerving Anyway - to the point - is it a mission? I'm guessing you take top yoke off unbolt and slide up, however how hard is it to get the throttle etc off? Want to do it for Sunday but don't want the headache of it before then if it's going to be agg. Thanks in advance chaps
Quite easy Jimbo , Take the top yoke off unbolt the switch gear take the grips off , loosen the throttle an clutch , then unbolt the clip ons an slide the clip on,s off the forks an slide the throttle an clutch lever off. To fit just slide the throttle an clutch lever on then fit the clip on to the forks . ( Take the grips off by sliding a screwdriver up the grip an squirting degreaser up the grip . Refit the grips by soaking the inside or the grips with degreaser or brake cleaner then quickly fitting the grips before it dries.
