any body got a link to any info on how to Change rear shock spring ( 2013 ) Or a guide ? Any special tools required? Cheers in advance .
A Shock Spring Compressor or compressors depending on type chosen, as well as the relevant tools to remove/refit shock from the bike. Don't remember what's on the blades oem shock but often there is a plate or a clip that you remove which allows the spring to slide out, fitment is like a Haynes manual says refit in reverse order!
