Cleaning chain and rear sprocket
Discussion in 'Maintenance' started by jampop, Jan 28, 2018.
  1. jampop
    jampop Active Member
    3496CCCC-1BAA-4236-9DF7-7A3F39C0756E.jpeg hi, what’s the best way to clean the chain and rear sprocket thoroughly. I’ve attached a pic. Is it best to remove the wheel. Or simply clean it.
    I have astonish engine degreaser and GT55. Is there something better to use. And is it best removing them or clean as is. Just want it clean for the new bike season. Any advice would be great. Cheers.
  2. nigelrb
  3. jampop
  4. Nigelg79
    Nigelg79 Active Member
    Don’t use a harsh degreaser, it’ll wash out all the good grease in the chain seals. There are loads of chain cleaner sprays out there that’ll do the job. Best and cheapest is kerosene imo. Make sure you rinse it off well with water afterwards, dry well then lube.
    WD is good for regular light cleaning, soaking a clean rag and rubbing it along the chain. I wouldn’t deep clean a chain with WD though myself. Just personal preference.
  5. Nigelg79
    This is a good vid
  6. bradt
    bradt Elite Member
    Paraffin always works for me for removing muck and old lube from the chain and shite from the sprocket and it's cheap and effective.
  7. Nigelg79
    Kerosene, paraffin - tomato, potato :D
  8. bradt
    bradt Elite Member
    Kerosene just sounds posher
  9. DazK
    DazK Active Member
    or aviation fuel sounds better
  10. Selmer50mark
    Selmer50mark God Like
    Once a year red diesel with a tooth brush ( mine not the wife's ) that's what I use, put a sheet of cardboard between wheel and chain to keep it off the tyre , give it a good wipe clean then lube with ep 80/90 gear oil on the inside of the chain . The 918 I got at 21,000 now has 39,000 , never changed the chain and sprok still in good Nick , the RR7 still on original at 9,000 . I re oil every 250 mile . Sad I know o_O
  11. PauloHRC
    PauloHRC God Like
    I plan on cleaning my chain and sprocket this weekend, to do a thorough job without getting shite everywhere, I'm removing the rear wheel so I can get to the sprocket properly by removing it from the wheel (might even replace it with a shiny new one) and also let the chain hang down and bath it in cleaner.
    I've bought a MOTUL chain clean and lube kit that includes a handy brush, so hoping it all comes up like new!
  12. nigelrb
    Did you read Lozzy's recommendation for 'Wurth' chain lube? I bought some, and applied it the other day. Haven't had the bike out yet so can't give a personal report.
    https://www.sportsbikeshop.co.uk/motorcycle_parts/content_rev/29605
  13. PauloHRC
    PauloHRC God Like
    Yeah I did Nigel, but I bought this a few months ago and just been waiting for the time to get round to using it!
    Never used it before but just seemed like a good deal.
  14. PauloHRC
    PauloHRC God Like
    It's in MCN's top six review's and does everything you'd want.....clean's well, dries well, long lasting and doesn't fling off.
    We'll see how it performs.....
    Watch this space!;)
  15. Jez
    Jez Senior Member
    I have a gold wheels I cleaned the chain once and applied some normal industrial chain lube, never again,after first ride spent about 4 hours cleaning the wheel and everything else. I now use wurth dry lube. spray on when the chain is warm after a ride, now I have no more mess. fully recomend
  16. Lozzy
    I've used Motul & although it's not as bad as some, it does fling a bit initially.
  17. Kevin1
    Kevin1 Elite Member
    EEEeeee those were days when we took the chain off and put it in a hot bath of molten grease.
  18. nigelrb
    Ah, it's a steep learning curve. Perhaps we've all been there!
    Much easier no though, compared to cleaning around spokes and chrome rims!!;)
