Cleaning Chain
Discussion in 'Maintenance' started by mattwill12345, May 17, 2013.
  1. mattwill12345
    mattwill12345 New Member
    I have a RR6, I have cleaned the chain with degreaser, and it's now all clean, but at the small cog end, i can't get to it to give the cog and it's casing a clean, Can I unbolt it or will I leak clutch fluid as it seems that part of the clutch is bolted to this casing, Thanks for the help.
  2. Andrew
    Andrew Active Member
    You can unbolt it without losing fluid, I removed mine to replace the chain and sprocket last year.
  3. racman
    racman Active Member
    remove gearchange linkage arm pinchbolt, noting alignment. remove the clutch release cylinder mounting bolts x 3 and carefully pull aside. put cable tie around piston if worried about it being displaced. remove pushrod. you can now clean till your heart is content. hope this helps
