clip ons and brake hoses
Discussion in 'General 1000RR Discussion' started by Kstead, Mar 6, 2015.
  1. Kstead
    Kstead Active Member
    Hi all
    Have fitted some new clipons and now the bottom banjo hits the fairing above the air tube, Ive gone HEL 2 line and the double banjo set up just wont go. Any ideas???? no one seems to do a 3 line kit anymore???
  2. Blackness
    Blackness Active Member
    Stick a picture up dude, let the dog see the rabbit !
  3. PeterT
    PeterT Active Member
    Yes I had the same problem when I changed my bars. Even using a single line set up from the master cylinder the bolt still fouled the fairing.
    I had no choice but to upgrade to a Brembo 19 rcs master cylinder
    • Optimistic Optimistic x 1
  4. sinewave
    If things clash then adjust accordingly!
    Taint rocket science! :p
  5. Kstead
    is an rcs ok then????
  6. Kstead
    im on it ........ this may take a while lol
  7. sps170373
    Are they raised if not that's possibly the problem as later blades need raised clip ons or they fowl with the body work, what year is the bike
  8. Kstead
    Its an rr8
  9. Kstead
    pics
  10. Blackness
    Bummer... Variobars or RCS's for you then mate unless you take a dremel to the bodywork o_O !
    Suppose the lever is well out if you move it to get clearance !?
  11. graemewalker
    graemewalker Elite Member
    You could have got harris gp clip ons to match those levers and would have had adjustment to clear fairing
  12. Kstead
    £150 plus vat & post!!!!
    erm.. needs to be cheaper to crash than that
  13. Kstead
    they do look nice though
  14. graemewalker
  15. dessp2
    dessp2 Well-Known Member
    Graeme (I don't know how to) but can you PM me mate, I may need some advice about a Fireblade SP:)
