Can anyone recommend clip ons and rear sets for a cbr1000rr 2007 please. It’s not for road use. I don’t need the best but I don’t want to inadvertently fit garbage. Thanks.
Are you just looking to change the angle Mark, or are you looking for something a bit trick? Did I tell you about grinding off the locating pin on the original bars? I've done exactly the same to the BMW too.
Depending on the angle of the oe bars if you put the left on the right and right on the left upside down they can come out a flatter profile.
lol, no worries. If you undo the bolts where the bars clamp onto each fork then you can slide them down the fork leg and get a Dremel drill (or similar) in to cut the locating lugs off. There's enough room to get a cutting tool in without having to remove the bars. I managed to get one of these in as the clamp is only made of aluminium.
