Clock resetting ?
Discussion in 'Maintenance' started by wedgiewolves#223, Mar 28, 2013.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    Hi there anyone else had problem with time clock resetting to 1:00 seems to when I've changed over from road to track fairings ? Maybe fuse cheers everyone oh 2012 cbr1000rr
  2. IcarusGreen
    IcarusGreen Elite Member
    It will do it if you disconnect the battery.
  3. wedgiewolves#223
    Na it's every time I turn key off and back on cheers bud I should of explained better
  4. RRdevil
    RRdevil New Member
    Funny. Mine seems to lose time
  5. kpone
    Is anything else on the LCD resetting to factory default, kph/mph etc. To hold it's settings it must be constantly live from the main battery or have a battery back up in the unit itself. With the fairing coming off I'd be suspicious of a multi plug being jarred.
  6. phantom
    phantom Active Member
    I'll put my money on a blown fuse.seen it happen loads of times.
  7. wedgiewolves#223
    I'm thinking fuse as my indicators not working well there isn't any on it but display would still work
  8. wedgiewolves#223
    Well
    #8 wedgiewolves#223, Mar 28, 2013
  9. wedgiewolves#223
    Fuses all sound . Only other thing I can think of is that I had a second headlight loom that I chopped down so all it has on is the clock plug . I might of cut a earth or wire that runs the lighting on the clocks as I noticed that the indicator light does not work or the hazard which is the same on clocks also the flash blue one does not light up when I flash . But my fuel light is fine mph and rev all working so is my gear indicator so for track I don't think it would matter just clock resetting
  10. phantom
    does the hiss light flash?
  11. wedgiewolves#223
    No I turned this off though in the settings bud on the clocks but have not tried to turn it back on
  12. phantom
    well the power that supplies the clock permanent feed does the hiss
    too so if its off too you will have to trace it back to find the fault.
    both are on a 3amp fuse if I remember right.
  13. wedgiewolves#223
    Hiss light not flashing just been in and set it too on but no flashing but also all fuses ok the only thing it can be is my cutting of the second clock loom I must of accidentally cut whatever sent the live feed to clocks
  14. phantom
    start from the 3 amp and work your way forward to find the break.
    trying to trace from the clock back is a far harder job.
