Clocks speedo
Discussion in 'Maintenance' started by gringo, Oct 8, 2016.
  1. gringo
    gringo Active Member
    If I take my clocks off will they just return to Normal when I plug them back in again as revs are sticking so want take it aperture to see why
  2. Muffking
    You'll have to set the time and the trip will reset, but that's it.
  3. gringo
    Thanks mate
  4. gringo
    Any one know if I have to take fairing front part of to get clocks off .as it got screws on back holding it on or is it just on rubber bungs and it just pulls of
  5. sps170373
    Will be screws going through rubber mounting grommets that dampen the vibration into bushes in back of clocks
    In the 08 onwards you have to take front cowl off to access these probably the same on earlier models
