Clunking noise 08 blade
Discussion in 'General 1000RR Discussion' started by clivo69, Jun 6, 2016.
  1. clivo69
    clivo69 Active Member
    Hi all iv got a deep clunking/clacking noise coming from round the front sprocket area on my 08 blade seem's to be there on every rotation anyone shine any light on this matter.
  2. blake7
    blake7 Active Member
    Lift the front wheel off the ground and give it a good spin. Could be wheel bearing, disc or pad issue.
  3. clivo69
    Thanks i will investigate
  4. Slimwilly
    Slimwilly Member
    Maybe stiff link in the chain
  5. ColinBR
    As above. More likely to be a stiff link on the chain.
    Could also be the rear wheel/sprocket bearings
  6. blake7
    Ignore my post above, I read it as noise from front end for some unknown reason. Plonker.
