2014 Fireblade SP. Is it possible to tape old clutch cable to new one and just pull through removing adjusting nuts obviously. Don't really want to pull fairings off. Has anyone done this before ? Any help would be much appreciated.
just replaced mine today, right fairing off unfortunately, the time you spend fiddling in the dark you wish you removed them in the first place. Tip remove/pull from the lever end and replace the opposite way. Didn't bother tying the old cable to the new one and pulling through as the routing is quite straight forward.
