clutch cable
Discussion in 'General 1000RR Discussion' started by tony lomas, Nov 16, 2015.
  1. tony lomas
    tony lomas Member
    Hi any one changed a clutch cable on a blade before if so was it easy my bike is a 10 plate cheers
  2. And7rp2
    And7rp2 Elite Member
    Very easy just make sure you route the new one exactly the same as the old one
  3. tony lomas
    tony lomas Member
    Does the tank need to come off .I've broke the plastic sleeve which is on the end of the clutch cable whilst fitting new levers .I've tried to get a replacement but the dealer says it comes with a new cable typical
  4. And7rp2
    From memory I don't think the tank needs to come off but the tank cover needs to, if you remove the cover its easy to see which way it's routed
  5. tony lomas
    tony lomas Member
    Thanks mate appreciate it
  6. Slick
    Slick Elite Member
    Did mine last year, easy but can be fiddly.
    Much easier if you take the right fairing off.
    The cable is snuck in between the engine and rad then between the engine a frame, before you pull out the old one tie a long piece of strong twine to the cable then attach to the new one, this will ensure you use the same routing.
    Also helps to take a few photos especially round the routing from the dash down to the rad and into the frame just for reference!!!
    #6 Slick, Nov 17, 2015
  7. tony lomas
    tony lomas Member
    That's great thanks for that looks like I'm going to be busy cheers mate
