Hi all i spent some time reading through different clutch posts but can only seem to find "clutch not working" ect. so I was out riding a few weeks back and after about 15 min of riding I started getting what I can only describe as friction or feed back in the clutch lever, it was intermittent and although clunky I could still change gears. Once stationery, if you pull the clutch lever in and out there's a high pitch noise, hopefully i can upload the video. (drop box link below) Since the above has happened I have replaced the clutch, completed an oil change and bled the the clutch, after all this I took it out for a test ride, everything felt really good, the gear change was really smooth and then after about a minuet of being out it all came back. https://www.dropbox.com/scl/fi/c9yp...ey=ynsl1ht9k72sxrc65j5k0exu4&st=i97dm02p&dl=0
