clutch hub bolt torque on cbr1000 rr4
Discussion in 'Maintenance' started by daz1, Aug 28, 2015.
  1. daz1
    daz1 Active Member
    can anyone give me the torque setting for the hub bolt in ft/lbs please thanks
  2. red5
    red5 Well-Known Member
    If you mean clutch centre lock nut
    128N.m
    13.1 kg.m
    94 ft.lb
  3. daz1
    daz1 Active Member
    Yes mate thanks
  4. lexathon
    lexathon Active Member
    Do you know the torque for the cover bolts around it? Just fitted an r&g engine slider. Only hand tightened and not too much because I had read 12 Nm in my old vfr800 manual but that sounds pretty loose?
  5. red5
    Yes 12Nm.
  6. lexathon
    Perfect - thanks!!
