Clutch less change
Discussion in 'Maintenance' started by Givover, Aug 11, 2011.
  1. Givover
    Although it seems to be recommened i have done it a few times and its all good .However i am still not sure if there is no potential damage caused by not using the clutch.Any skilled fitters out there with a technical answer?
  2. kpone
    Bugger that. My box is clunky enough with the clutch.
  3. dan.1moore1
    well you can buy a quick shifter for clutchless up shifts, granted they are for full throttle upshifts but if changing with out a clutch is harmless then i doubt people would buy buying these.
    I'm no expert but using the clutch is probably cheaper than replacing the clutch. its not as if its a pain to use or anything
  4. Remal
    Some do some don't. Always use the clutch for down shift. After my track day I was told not to use the clutch for upshifting and worked well. Not doing tHe same on the road. But do it when using more revs as not enough seem to make it clunky. And again told it does not damage the clutch
  5. megawatt
    megawatt Well-Known Member
    Usually when riding fast I don't use the clutch for upshifts. Just apply a bit of pressure under the gear change and blip the throttle!
  6. Nutty Tart
    Nutty Tart Well-Known Member
    Yup .. me too .... when i'm riding fast ... but if i'm just pottering about in towns always use the clutch
  7. fisher
    fisher Active Member
    I've always used the no clutch upshift on all my bikes and never had any problems
  8. Si.
    yup, me too.
  9. tonyblade
    tonyblade Active Member
    No clutch here as well. You don't need it, match revs and it's smooth as.
  10. zeepony
    zeepony Active Member
    I dont even use the clutch for unshifting when comuting into London. I've ridden like that for ages, and if anything, I'd say I'd reduces clutch wear, as it's used 50% less.
    The fueling on the blade is soo good, you can do it at any rev range.
  11. flatstickHRC
    flatstickHRC Active Member
    i never use the clutch going up the box ever. its much smoother without the clutch and doesn't hurt the gearbox at all
  12. Moily
    Moily Active Member
    +1 for the clutchless upshifts.
    I read a few years ago how they were better for the gearbox (although can't remember specifically why now!), and once you get the hang of them they feel so much better than when using the clutch.
  13. JM1
    JM1 Active Member
    I'm not a "skilled fitter", but can tell you that clutchless upshifts done correctly will not damage the bike in any way.
  14. Givover
    Thanks all looks like its Clutch less for me then .
  15. bladebhoy
    bladebhoy Active Member
    yep big thumbs up for clutchless upshifts.
  16. Gums
    Gums Active Member
    don't use the clutch on upshifts, only going down the box.
  17. slowr1der
    slowr1der Active Member
    Blip the throttle for a clutchless up shift..........interesting as i do the complete opposite and roll off very slightly click her in and then wind it on
    surely blipping with no clutch would just lurch you forward Alan
  18. MrB
    MrB God Like
    Another vote for crutchless er I mean clutchless
  19. Remal
    been doing many more clutch less up-shifts and the Bazzaz quick shifter is fun and sounds nice.
  20. kev1382
    kev1382 Active Member
    iv never used the clutch for upshift on road or track,
