Clutch not engaging
Discussion in 'Maintenance' started by Ionized_Monster, Nov 12, 2023.
  1. Ionized_Monster
    Ionized_Monster Active Member
    I have a 04 with only 10000 miles on it, the last few time's I've ridden it's felt as if the clutch cable has stretched and it's now hardly engaging at all so I can't find neutral whilst it's running.
    I've looked and it appears to be a hydraulic clutch hose, do they still wear over time like a cable would? If not any suggestions on what it could be?
  2. Selmer50mark
    Selmer50mark God Like
    No they don't wear out, it could be air locked and need bleeding, if that's the case you might as well change the the fluid and flush the old out, it needs replacing as part of the maintenance schedule
    • Agree Agree x 2
  3. raphael
    raphael Elite Member
    As said above mate, just needs fresh fluid flushed through and bleeding,did mine yearly with the brake fluid
  4. Barstewardsquad
    As said above probably just needs new fluid and/or bleeding. Whilst there check the actuator for seepage.
  5. Ionized_Monster
    Thanks all for the info, I shall look at it when I get a chance next weekend hopefully.
    I had the brakes done at the start of the year but wasn't aware of the clutch being hydraulic until now so didn't have it done.
  6. Muffking
    Same here. I had to bleed mine at the slave cylinder at the beginning of every season.
  7. Broadie
    Broadie Active Member
    Worth taking of to get all the old fluid out.
