Clutch Vibration - Please Help
Discussion in 'Maintenance' started by Simon Edwards, Mar 27, 2017.
  1. Simon Edwards
    Simon Edwards New Member
    Hi all, I`ve owned my 2012 anniversy Fireblade since just before xmas and its been a dream to own and ride but whilst out for a Sunday blast (weather was rude not too!!) I`ve noticed a vibration. If i`m sat in traffic and with the bike in 1st/2nd gear and the clucth lever pulled in it feels normal but in neutral theres a vibration right through the bike and i think i can also feel it in 1st gear at low rpm poodeling along but then goes once you get up to 15mph roughly. I`m unsure as to wether there may be a issue with the clutch and worried it may get seriously worse if i continue to use her or wether there`s no issue at all? Any ideas peeps or has someone else had the same problem??
  2. Mr OCD
    Mr OCD Well-Known Member
    It's the clutch basket ... :)
    They all do it Sir ...
    Sit in neutral... clutch out, then pull lever in... then let leaver out ... you'll hear / feel the difference.
  3. Simon Edwards
    Thanks MR OCD!! was begining to panick for a second:confused:
