Contaminated Tyre
Discussion in 'Maintenance' started by Sulby140, Mar 31, 2014.
  1. Sulby140
    Sulby140 Active Member
    Gents,
    Wee problem, recent holed rad sprayed coolant over the RH front brake and tyre, brake is fine and have washed and scrubbed the tyre. Pretty sure ok in the dry but in the wet? Unless someone can suggest a cleaner looks like I'll need to replace the 1k front.....ideas welcome...
    Cheers Mike
  2. garyauk
    garyauk Active Member
    Your tyre will be fine mate
  3. sps170373
    You should be ok mate, might be worth to just give it all a hose down again to be sure
  4. raphael
    raphael Elite Member
    just had the same fella! i used muc off degreaser hot soapy water and a scourer and was fine the next day in the wet just go steady and see how you feel after
  5. Mike07
    Mike07 Active Member
    Plenty of soapy water, it will be fine. Think of what it runs through on the road all the time, if a bit of antifreeze was going to kill it your tyre would not last two mins.
    Mike.
  6. SIDEWAYS
    SIDEWAYS Senior Member
    The thing you need to worry about rubber on tyres is if it has been imersed in an oil or an acid.Coolant is ok cos it does not harm rubber only after long years of it going past its effectiveness then it becomes acidic and corrosive.As others have said soapy water would be fine.
  7. Sulby140
    Thanks guys. I'll give it another clean as a precaution and take it steady until I'm ok with it.
    Mike
  8. martinowen
    Clean it and forget about it or it will be in the back of your mind for ages and ruin your ride!
  9. Nick_BladeRR
    Nick_BladeRR Active Member
    +1 on this
  10. glynn
    glynn Member
    Think how much **** there is on the roads, the tyre will be fine.
  11. Sulby140
    Cheers guys,
    200+ Wednesday and today, no issues including wet, btw West Mercia Radiators did a good job on the rad, also returned it immaculately clean..took a week from sending to return....
    Mike
