Cooling fans kick in temperature 2009 fireblade
Discussion in 'Maintenance' started by desi1, Dec 31, 2014.
  1. desi1
    desi1 New Member
    Noticed one fan kicking in on my bike at around 78 degrees. Is this normal on the blade?
  2. Garyb
    Garyb Moderator.
    78 seems low?
    Usually around the 100-104 for the fan to kick in on my 2010.
    I'm sure some clever types will come along with some ideas and what to look for very soon. :)
  3. Philhasasti
    Philhasasti Active Member
    Yes mine is the same. 78 seems a bit early.
  4. desi1
    desi1 New Member
    I had the airbox off it and started it and noticed one fan kicking in at about 78 degrees mark. The second fan kicks in at about the one 104 mark. Dont know if is normal for one to kick in at the lower temperature.
  5. desi1
    desi1 New Member
    Just checked the owners hand book and it says it normal for it to some times come on at the lower temperatures if the engine is revved. Thanks for the replies.
  6. Garyb
    Garyb Moderator.
    Not sure mate, but the 78 would be a niggle more than a concern for now. An early fan must be better than no fan I'm sure
  7. Slick
    Slick Elite Member
    102 for the big fan, 106 for the smaller one.
    Manual does refer to the fan kicking in earlier if reved but never noticed it myself.
  8. Gilesy
    Gilesy Elite Member
    My 2006 often does this.. Comes on around 80, then again at 106-ish
