Correct rear spring
Discussion in 'General 1000RR Discussion' started by Willie 1000rr, Jan 21, 2018.
  1. Willie 1000rr
    Willie 1000rr Active Member
    Hi all.
    Anyone help out please?
    Have an ohlins ttx shock fitted but think spring is to heavy. How do u read the code or know what spring you should have fitted for your weight etc?
    Any advice be welcomed.
    Thanks
  2. TheMickster
    TheMickster Active Member
    Hi
    It's the last few numbers of the code on the spring e.g -36/105.
    Couldn't find anything for Honda but found some charts for Yamaha with the following weights:
    P.N. ____ Spring # ______ Rider Weight
    YA 638 21040-31/95 ..... 150 - 175
    YA 638 21040-34/100 ... 175 - 200
    YA 638 21040-36/105 ... 200 - 225
    YA 638 21040-39/110 ... 225 - 250
    YA 788 21040-31/95 ..... 150 - 175
    YA 788 21040-34/100 ... 175 - 200
    YA 788 21040-36/105 ... 200 - 225
    YA 788 21040-39/110 ... 225 - 250
    I've got a 105 on mine and weight about 15 Stone with gear on, so seems about right with the weights above.
    Cheers
    Mike
    • Disagree Disagree x 1
  3. cronester
    cronester Active Member
    My 2016 SP came with 110 spring as standard so I changed to a 100 as I am about 12 stone and this seems to work well for me.
