corrosion issue on 14 blade wing mirrors
Discussion in 'Maintenance' started by dave h, Jul 24, 2016.
  1. dave h
    dave h Active Member
    Hi. I'd be interested to know if anyone has had an issue like this. The bike is less than two years old and has paint peal / corrosion on wing mirror stalks / mounts, seems odd for a bike of this age. It has been kept dry in a shed and only ridden in summer.
  2. Cbrjay
    Cbrjay Well-Known Member
    Take back under warranty?
  3. Kentblade
    Kentblade God Like
    Yes mate, same issue, Within 9 months they were peeling, the arms are cast and the only explanation was that the paint finish was applied incorrectly. Bearing in mind they are the same from 08, must have been a faulty batch at that time.
    Changed both under warranty, no quibbles. Replacements are fine.
  4. 1000rr73
    1000rr73 Active Member
    Don't know about the corrosion but you got a seriod problem with flies up there!
  5. Ian E
    Ian E Active Member
    Mine and a mates 2014 RREs are fine - as above take it to the Dealers and get it done under warranty.
  6. dave h
    Excellent, cheers
  7. Jez
    Jez Senior Member
    Hi, mine is a 2013 I bought it at 2 years old and it had corrosion on one side. I sanded down and repainted.
  8. stevet
    stevet Active Member
    Got my 64 end of 2014.....everything still spotless....got 2 bikes so only put 4500 miles on it though...i'd be pullin me hair out at them mirrors
  9. stevet
  10. levin
    levin Active Member
    My 2014 has corrosion on the lower part of the mirror arms after been parked in the shed for the last few months :( only 5k miles on it , they were perfect last year but my shed is a lean 2 off a garden wall and tools etc do corrode in there , racing over the mirrors tho, may get them sprayed ,I wonder could they be taken apart and powder coated
