(Daft) Question about exhaust fitting
Discussion in 'Maintenance' started by callumw, Mar 10, 2013.
  1. callumw
    callumw Active Member
    Do..... you need to use exhaust sealant paste when fitting a new slipon (Akra race) or are the clips good enough to crimp and seal the pipes?
    I've used I on cars in the past, but don't know if the same applies to bikes too
  2. phantom
    phantom Active Member
    I never, cant comment on how loose or tight Akra's fit
  3. gray
    gray Active Member
    Just used the clamps mate when I fitted my scorpion, two brothers and the full arrow
  4. scooby
    scooby Elite Member
    prings are enough to give a proper seal,gasket seal can make a real mess+it's hard to get it off again.
  5. martinowen
    Mines just held on with springs
  6. Slick
    Slick Elite Member
    Wouldn't bother with paste, as said by Scooby it makes a big mess and removal a bugger.
    As it's new the mating surfaces will be undamaged so should fit perfectly. I bought a second hand Leo V once where the previous owner over tightened the clamps damaging the tubes. Had to use paste to make airtight. It set so hard couldn't remove when I came to sell!
  7. callumw
    Thanks guys :)
  8. Remal
    Yup after taking mine off was just the Springs. I use Exhaust Paste on my kit car but never heard of it being used much on bikes.
    Anyone know why? out of interest
  9. callumw
    At a guess - perhaps the car exhaust's are more prone to torsional twisting due to their length?
    + the springs will probably pop off with all the f*king speed bumps smacking into the 'zorst
  10. kpone
    My Akra slip on had a big, soft deformable, copper seal that crushed flat as the bolts pinched up and sealed it.
    But yes, Callum's right. Car engines move a lot, bike engines hardly at all. I've seen racing cars with sprung junctions between manifold and pipe but they don't need MOTs.
    #10 kpone, Mar 11, 2013
