anyone got DanMoto rearsets and fitted an aftermarket exhaust like a Yoshi R77 or Akro. Got a Yoshi r77 delivered the other day and last night tried to fit it. I noticed when I got it on there isn't anywhere on Dan Moto rearsets to fit the exhaust to. Unless I'm missing something? I had the same exhaust on my last blade but it had Gillies rearsets which I think had a bracket for such exhausts. Anyone got close up pictures of how your Yoshi's are fitted to the rearsets? Even better if you have done it with DanMoto rearsets? Here's pictures of it offered up but not fitted. Any ideas?
Reading into a bit more it seems DanMoto rearsets are a budget make. I've never come across them until I got this bike with them on. Having said that I'm convinced there should be another bracket that bolts onto the back of the rearsets to hold the exhaust. Even if it's a standard exhaust. Surely aftermarket rearsets would make make them with a bracket to hold the original can on. Has anyone got a set of these or has had them in the past?
Im using bonamici rearsets which has a bracket which stretches across for an exhaust mount. Not the clearest pic but you get the idea.
Yeah that's the exact thing I need. Every aftermarket rearsets must have a similar thing otherwise there would be no place to bolt the standard exhaust let alone another can.
Alot of rearsets you can buy spares for, maybes you can source one. If not it should be easy enough to make.
