Dark screen probs,
Discussion in 'General 1000RR Discussion' started by irish eric, May 16, 2017.
  1. irish eric
    irish eric New Member
    Hello ,anyone else got issues with the clock display plastic surround on a 16 blade ?couple of months after buying it I noticed it starting to bubble up ,it was replaced under warranty but I was told if it happens again it won't be covered ,apparently it's because of the dark screen they supply as an extra when new !now if they know it's an issue why are they supplying it ??and it's not as if I live in the goby desert [emoji3][​IMG]
    Sent from my iPad using Tapatalk
  2. dansp1
    dansp1 Active Member
    double bubbles do that....
  3. irish eric
    Yep seems to be a common problem !
  4. Naz
    Naz Active Member
    With the zero gravity screens you get a warning about that happening if left in direct sunlight and I believe with the puig screens you get some kind of card cover for your clocks
  5. dainesefreak
    dainesefreak Senior Member
    Yes the Puig screen comes with a shite stick on surround. Mine stuck to the clocks for all of 10 minutes standing still in the garage. Can't fault the screen though. Not a problem for me as I'm either moving or it's in the garage.
