Quick question Are 2004 to 2012 the same size front discs. Are they the same offset if that's the right terminology Thanks
2004-05 were 310mm after 320mm think offset is the same but not 100% as it's the front wheel that needs machine work on 08 plus wheels to fit 04-07 blade but sure a true expert will be along to confirm Just looked on caprimoto site and the 06-07 disc do have a different part number from the 08 on 06-07 78B40877 08+ 78B40876 So guess there different but both 320x94 mm 6 hole
