Does a slipon require remap?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Pete, May 17, 2012.
  1. Pete
    Pete New Member
    G'day,
    I'm thinking of replacing the stock can on my 2011 CBR1000RR, mostly for the sound. When I've done this on carbed bikes I usually re-jet. Does a slipon require a re-map?
    Pete
  2. slowr1der
    slowr1der Active Member
    Usually no but you may get a flat spot around 3500 revs. To get the best out of the fueling tho it would be better to get it on a dyno with the new pipe
  3. Swiss T
    Swiss T Active Member
    Have you disconnected the exhaust flapper; makes the standard can sound a little meaner?
  4. rm2092
    rm2092 New Member
    I agree with that, I went with the Leo Vince slip on and NO mapping required and it runs GREAT...
  5. Remal
    AS said not normally but I have found it made a big difference once I had my bike set up on a Dyno. I ran my blade for a year with my Yoshi R77 and only had in March it set up. Ok I had a BAzzaz fitted and K&N filter. but have found the bike pulls very well and no flat spot.
  6. kpone
    Mine came with an Akrapovic slip on with no re-tuning and it ran okay, but over fuelled a bit while pootling so it was jerky when commuting. With the original can back on the over fuelling disappeared and, to be honest, didn't sound a great deal different.
  7. JM1
    JM1 Active Member
    With an after market pipe, the standard map would under fuel if anything I think? (ie, run lean)
  8. gixerator
    gixerator Active Member
    you would notice the difference if you had to carry them both around, I know which Id drop first.
    The OEM is as heavy as a large skip!!
  9. dan.1moore1
    You cant just remap the bike . you need to buy a power commander or Bazzaz unit to intercept the ecu's map .
    These modules don't make the maps better , just makes them possible . both have different features and benefits so do some research
  10. Pete
    Pete New Member
    Thanks guys, I was worried about leaning it out. A Mass Airflow FI system would automatically compensate for any increased flow. Does it work like that on these bikes?
    Might start with removing the flapper - is this easy?
  11. kpone
    Ah, it's the other way around. I was going on what the guy at Bridge told me when I told him about it after the test ride.
    Actually, I was surprised it wasn't as heavy as it looked considering it looks like something NASA drops into the Atlantic.
  12. Swiss T
