Donington Park - Noise levels
Discussion in 'Trackdays' started by RichC, Sep 23, 2013.
  1. RichC
    RichC Active Member
    Confuzzled quiet day 98db loud day 105db?? Is this not direct under a busy flight patch why such tight restrictions.
  2. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Because mallory park locals like to holiday near donnington on occasions..
  3. Repsol Rob
    Repsol Rob Elite Member
    Well the three families that complain 152 times between them do..... !!
    #3 Repsol Rob, Sep 23, 2013
  4. just_me _and _me _bike
    surprises me when i hear noise restrictions at race circuits, when if u stand by the side of any main A road in the UK uhear all manner of boy racers and theyre overly loud exhausts !!!! and surely why wud u move and LIVE nxt to / nearby a race circuit if u dont like the sound of motorised vehicles???? :confused:
  5. Yorkshire Tyke
    Boy racers now thats a whole can of worms... infact..
  6. RichC
    RichC Active Member
    It's shite my work contract has been delayed so I am sat at home for two weeks on full pay tempted to do a few track days was thinking about a early start at Donington as I fancy a change from the norm (Caddy) but S1000RR blows 100db now so only eligible for noisey day. YAWNNN
  7. scooby
    scooby Elite Member
    yep donny is a strange one regarding the noise,but tbh they do a lot of no noise limit days though.
  8. glynn
    glynn Member
    Sounds daft but how do they measure the noise, obviously with a sound meter but at what rpm, how close to bike etc etc. I've just measured my yoshimura rs5 end can with stock pipes and cat and its coming up between 81 and 90db. It sounds much much louder to me.
  9. scooby
    scooby Elite Member
    donnigton dont do static tests,they have meters around the track (think 3 in total),and if you trigger it,then they black flag you.
    whe you say measured,at what distance,what rpm?
    at oulton for a thou it's 5.5k
  10. glynn
    glynn Member
    I measured about a meter away at same height as exhaust and just off to the right. I measured between 4k and 7k.
  11. Muffking
    That reminds me, there's an App for this on the iPhone. I must compare this to the 101db reading that i made at Cadwell.
  12. Repsol Rob
    little Donny tip.....stay far right hand side of pit straight until you get past pit entry onto track..... they measure you on a fly by there so as long as you are just about there on db levels you should be ok......
  13. Repsol Rob
    What can have you got ?
  14. Muffking
    Or change up a gear as you approach the measuring points ;)
    Mine's a G-Force on the Triumph TT600 BTW, but i dont know if you meant me.
  15. RichC
    RichC Active Member
    Full race Akro on S1000RR around 103/104db ish
  16. Repsol Rob
    You might just make it on a fly by ? can you fit a db buster ?
  17. Repsol Rob
    Have you been measured before ?
  18. scooby
    scooby Elite Member
    if its' a 98 day you've no chance,trust me i know!!
    if it's an unrestricted then your fine.
  19. Muffking
    Only a static test at cadwell, but i could track down an appropriate sized baffle insert for mine as its got mounting holes in the tail pipe.
  20. Repsol Rob
    The focussed boys will be looking for a insert..... if they see nowt you ll be pulled up before you get out.... is it a focussed or no limits day ?
