Don't you just hate that !
Discussion in 'General 1000RR Discussion' started by Marky mark, Apr 8, 2013.
  1. Marky mark
    Marky mark New Member
    Guess the torque setting wasn't fookin tight like I thought!!!
  2. phantom
    phantom Active Member
    hate that when it happens
  3. derick
    derick Active Member
    Aw man. That kinda shit is the worst. Hate it with a passion.
  4. phantom
    this is why bikers need pillar drills
  5. ColinBR
    Small centre drill to start with, then use a 3mm drill to drill in the centre. Then finally use and easy out (screw extractor).
    I just done 1 on my SP1 a couple of weeks ago. The guy before me had just glued the head of the screw back on after he had sheared it :eek:
  6. blade1980
    blade1980 Active Member
    What year, recently did mine in the winter front disc bolt is 20nm that's for a 2010 if it helps
  7. Marky mark
    Managed to get it out, welded an Allen key onto it and slowly worked it out of the half ton of thread lock that I got carried away with. Had to be careful as I've only just has the wheels powdered! :( Clolin i was also tempted to super glue it back and ignore it.
  8. Clarkey
    Clarkey Member
    Glad to see hear you got the bugger out
    Also nice to see another black n white blade
    With white wheels
  9. Marky mark
    I know what I like and it's black and white,black and white and a bit more black and white! It's the way foward !
