Drift camera mounting
Discussion in 'Lounge' started by phantom, Jun 24, 2013.
  1. phantom
    phantom Active Member
    Has anyone mounted a drift camera to their blade before
    and if you have what way did you do it.
    I have to mount one as I have been asked to record a few sections
    of local roads for a promotional video.dont really want to use the 3m
    pads as I am worried about damaging the paint when it comes time to
    remove it,
    thanks ;)
  2. Moily
    Moily Active Member
    I have a Drift HD with the plunger mount:
    I tried a few places on the fairings but with the plastics being so thin the smallest bump in the road will make the camera judder. The only place I could find was on the flat top of the side fairing (underneath the switchgear) with the camera angled out, forward-facing and flush to the side of the bike. Hard to describe without a picture, though!
    A lot of people mount theirs on their lid, which may be the optimal solution although I tend to move my head around quite a bit so would depend on your riding style, I think?
  3. Corki
    Corki Active Member
    The way to get them off a helmet is with a hairdryer and a credit card, with a bit of WD40 to help on its way. This should work on the plastics although be careful with the hairdryer if near decals.
  4. Pete H
    Pete H Active Member
    Zeepony might be the man to ask Phantom.
    I believe he uses one occasionally.
  5. phantom
    yeah I use the helmet mount but for a road guide I wanted it more
    stable.I seen them suction mounts but I was worried about them ripping
    off in high winds.I might have to make some sort of bracket using the fairing
    mount.pity its upside down forks as I had looked at fitting it on the forks.
  6. Moily
    Moily Active Member
    The sucker is VERY strong. If the seal is good then once the vacuum is created you'll rip the fairing off before you get the sucker to release.
  7. martinowen
    Come off the front mud guard, I reckon it will give a great vid at that level too :D
  8. phantom
    maybe try that then, cheers for the heads up [​IMG]
  9. phantom
    thats the view I wanted but there isnt any room :(
  10. martinowen
    I have my tax disc attached down there, not sure if yours will be the same but can attach a pic of where if you want?
  11. Garyb
    Garyb Moderator.
    I'd perhaps aire caution to putting a camera anywhere near where the front end compressed under braking etc, not much clearance Between mud guard and nose come IMO.
    Top of tank works well for me.
  12. martinowen
    I mean to the side of mud guard, see where my tax disc is on this pic.......
    #12 martinowen, Jun 24, 2013
  13. Moily
    Moily Active Member
    No good if you have the tinted screen tho!
  14. phantom
    need some sort of mount made but thats got me thinking now ;)
  15. phantom
    thats why I didnt mount it under the nose, I had one mounted there on the duke
    but it was one of them slim bullet cams.
  16. martinowen
    Or buy Si or navy's broken mirror and mount there. But I reckon the vid would look good closer to he floor
  17. r1monkey
    r1monkey Active Member
    I put mine in the steering yoke stem hole , you can get a sat nav ball type mounting off ebay , you will need a couple of other mounting pieces to go with it though. They are called ram mounts.
  18. lambeth longshanks
    I think mounting it on anything unsprung is going to record too much movement no, Phantom?
    Do you have crash bungs you can mount it on?
    I have a light tint to my screen and a friend took photos through it with a iphone and the pics were fine. Didn't seem to pick up the tint to my untrained eye.
  19. phantom
    I was looking at the crash bungs already but I wouldn't know where to begin
    Trying to mount it on It.need to check what sort of mounts you can get on ebay.
  20. sinewave
    Email Baron-von-Grumble!
    I believe he uses a Drift Ghost HD now.
    Go-Pro is sooooo last year Darling! ;)
