Drilling visor for Pinlock inserts??
Discussion in 'Mods, Upgrades, Accessories and Products' started by ray, Sep 27, 2012.
  1. ray
    ray Well-Known Member
    OK I've picked up a brand new Genuine dark tint visor for my HJC for a steal.
    The only problem is, it doesn't have the Pinlock inserts already fitted :(
    Quick question, has anyone else fitted/drilled their brand new visor to fit the Pinlock system, and if so any instructions/how to & what not to do?
    As you can imagine I'm not looking forward to the thought of drilling my brand new visor :( :(
  2. Garyb
    Garyb Moderator.
    I guess if you attack it the same way you would, say drilling a tile, mask up mark it check check check again and drill, if you don't feel confident?
    Have a chat with these guys, they will drill it for £15
    Have a read here, the link is enclosed for the visor shop
    Motobke.co.uk - All about owning and riding modern motorbikes!
  3. ColinBR
    I drilled my girlfriends visor to fit the pin lock.
    First off I put the insert on the visor and made sure that it didn't get trapped or in the way when opening and closing the visor.
    I then marked up 1 side with a non permanent marker removed the insert and drilled that end, put the pin in that side, and re-fitted the insert again. Marked up the other side and drilled that end. Job done :)
  4. RedMacGregor
    RedMacGregor Active Member
    Just a warning you need to be very acurate in working out where the holes should be drilled. I tried fitting a pinlock to a cheap Shark helmet - took ages measuring and still ended up with it a little too lose. I'd pay the money and let the shop take the risk.
  5. martinowen
    Take the helmet off first
  6. ray
    Lol, thanks Martin.
  7. Muffking
    Yep, ive done 2. Tape across the visor. Measure and mark the holes. Use a smaller drill bit first. Hope the pins rotate to help with taking up the slack.
  8. ray
