DTC reset
Discussion in 'General 1000RR Discussion' started by mdubyah, Apr 10, 2022.
Tags:
  1. mdubyah
    mdubyah New Member
    Hi, On my 2019 RR SP I recently attempted to do a DTC reset ,with a paper clip in the red socket ( I had the engine warning light on, after fitting a new exhaust and removing the servo etc, adding a servo eliminator ), I now have a broken bike, won't start, with S4 S7 error on the dash, which I think is a general ECU/SCU comms error, also the fuel pump doesn't start on startup, along with a suspension exclamation graphic and a line for all the other settings; power etc. Have I fried the ECU?
  2. Fatboy
    Fatboy Active Member
    Have you done the Line Open Circuit Inspection between SCU34pin Black connector and ECM 39Pin connector for continuity as per manual
  3. mdubyah
    mdubyah New Member
    Hi,
    Thanks so much for sending over the information, I would have given that a go, but in the meantime I decided I best give it to someone who knows what they are doing so the bike is currently in the bike shop being looked at.Thanks again, and I'll post the rsolution to the problem when I get the bike back.
    Cheers
    Mark
  4. Fatboy
    Good Luck Mark , probably only dislodged a connector/wire while you were doing the other job;)
  5. mdubyah
    mdubyah New Member
    Well, the good news is that it was a blown fuse (10Amp), strange cos I checked the fuses, so maybe that one was somewhere other than in the fuse box, so now everything is working its back to the original probelm which was the traction light coming on solid after a couple of miles...
  6. Fatboy
    Could you have a wheel speed sensor fault
  7. mdubyah
    mdubyah New Member
    That sounds plausible
  8. Fatboy
    Or you could just try starting and stopping the engine , go through a few cycles , might go away
  9. mdubyah
    mdubyah New Member
    I will certainly try that, also have replaced the battery because it wasn't holding the charge very well, so maybe after a few rides this week it may resolve itself
