Just fitted dual head light module. Fitted module inside headlight housing so out off site completely & easy to get to if I need to re program,I also Changed red wire with black wire so the black links up head lights so don't stand out,and I all so used earth from high beam side instead of going straight to earth on battery .used male & female h7 leads so not actually wired into bike wiring .FIRST PICTURE LIGHTS ON DIP.SECOND HIGH BEAM ON.AND THEN WIRING & FITTING HIGH BEAM SIDE. LOW BEAM SIDE . GOOD JOB I THINK
Superb job Looks cool! ordered mine was hoping would turn up b4 easter weekend.... did you fit a relay or not bother I haven"t decided yet as wasn't sure of switch rating. Didn't realise module was so small will copy that!!!!!!!!!!!
Hi womblewizard,did not use relay I asked jens from supplier and they said do not need.to help any body bike wiring is high beam side wires are blue is live,ang green is earth .on dipped side White is live and green earth.and don't do what I did copied as drawing same way round then realised low beam is on the right and high beam is left on my blade
Does anybody local to me good with electrics that would be able to do this for me as I'm a complete novice when it comes to electrics
My only concern is the low beam wire is now supplying 2 lights therefore carrying more current, that's why I am using supply from high beam relay to back it up ( hope that makes sense).
