Ducati/brembo brake not working
Discussion in 'Other Bikes' started by hump333, Dec 12, 2013.
  1. hump333
    hump333 Member
    I noticed my brake leaver had no pressure in it the other day. I have bleed the full system. The pressure up now go for little ride and again No pressure? Pump it few times then pressure. . Ride bit more no pressure? Any ideas
  2. arthurbikemad
    Thought you fixed it mate, check the discs and wheel bearings, maybe warped or side play pushing the pistons back?
  3. sinewave
    You have a leak and or Air is being allowed in to the system, or sumats moving?
  4. hump333
    hump333 Member
    Sound did i Arthur. No leak no fluid loss. Push piston back check seals all ok? Pressure there if standing goes if riding 3? 3 pumps its back up.
    #4 hump333, Dec 13, 2013
  5. scooby
    scooby Elite Member
    does sound likr the pistons are getting pushed back in somehow.
  6. hump333
    hump333 Member
    I well strip again at weekend. Upload photos. Could this be master cylinder sucking air in, ?
  7. arthurbikemad
    Could be, they are a VERY simple design and are easy to strip (I think you have already?) seal could be split but then Id expect it to be weak all the time, hence why Id say its the pistons getting pushed back, a classic example of what you have.
    As I said many Ducati owners say they are 19mm too and they are not, they are 18mm if your looking for seals, again like I said Ducati do NOT sell the bloody seals but KTM etc should be the same.
  8. hump333
    hump333 Member
    Author its these EBC floating brake disc one of the disc is bad. The owner must of put second hand disc on it?
  9. arthurbikemad
    Ah! That's your problem mate, disc floats off center and pushes back the pistons as I though?
    Gutted as not a cheap fix! Brembo Oro are around £400 pair! OEM 848 discs are good, think 1098 etc run a 330mm disc and not a 220 like the 848, check the sizes of what you have before ordering anything, wonder why they ditched the very good OEM Brembo's?
  10. hump333
    hump333 Member
    Ive bought ebc the same disc I only needed one £138 so not too bad.
