evening all! i want to get my bike set up but not sure what i will need regarding parts? i have a 2012 with standard system with a yoshi r77 which i like and will keep. was thinking pc5,auto tune and o2 eliminator? is there anything else i can do for better more consistant results? also whats a realistic cost for that lot? cheers
I got a PCV with O2 eliminator from Demon Tweeks for £260 last week for my 07. Have a look on their site or ask them for a price in their section on here.
If you have an Autotune you will not need the 02 eliminator. The 02 eliminator is used when you disconnect the stock Lambda sensor. This stops the sensor sending info that would conflict with that held on the map of the power commander. If you fit the autotune they supply a wideband Lambda sensor which then talks to the power commander via another little black box. The new sensor is slightly larger than the stock sensor and might require a new adapter being welded into the exhaust. The threads on the stock sensor do not match the treads on the autotune sensor.
